Sun Joe Saw Joe 18-Inch 14-Amp Electric Chain Saw
We compared price of Sun Joe Saw Joe 18-Inch 14-Amp Electric Chain Saw across hundreds of online stores. We found Sun Joe Saw Joe 18-Inch 14-Amp Electric Chain Saw in 1 store with lowest price $99.98 in Sam's Club. For detailed price comparison of Sun Joe Saw Joe 18-Inch 14-Amp Electric Chain Saw check table below.
Merchant | Price | - |
Sam's Club | [show price] |
Sun Joe Saw Joe 18-Inch 14-Amp Electric Chain Saw description from Sam's Club
A cut above the rest. The Sun Joe Saw Joe SWJ701E 18" 14-amp electric chain saw combines power, performance and precision into one easy-to-use, reliable cutting tool. Premium power. Packed with a powerful 14-amp motor that starts instantly with the push of a button, the Saw Joe SWJ701E makes quick work out of thick limbs, firewood, logs and branches. Powered electrically, the eco-friendly Saw Joe SWJ701E performs reliably without having to mess with gas or oil or pollute the environment with toxic hydrocarbon emissions. Optimal performance. Getting the job done is easy with the Saw Joe SWJ701E. Its lightweight design (only 9.7 lbs.) and adjustable ergonomic handle work together to maximize comfort and minimize fatigue during use. Safety features include a hand guard with kickback brake and a switch to prevent accidental starting. Precision cutting. Featuring an 18-inch Oregon bar and chain, the Saw Joe SWJ701E tackles tough cutting jobs and can saw through branches up to 17-inches thick. The automatic chain lubrication system provides for long periods of continuous cutting without interruption so you can get the job done even faster. Backed by a full 2-year warranty and marked with the CSA seal of approval, the Sun Joe Saw Joe SWJ701E 18-inch 14-amp electric chain saw makes it easy to GET EQUIPPED for spring.
Customer review
My sister says: Buy this outdoor power tools! Now I see it was right choice!
