Vision X Optimus Square Single LED Light Pods XIL-OP110CKIT 10 Narrow Beam Pattern
We compared price of Vision X Optimus Square Single LED Light Pods XIL-OP110CKIT 10 Narrow Beam Pattern across hundreds of online stores. We found Vision X Optimus Square Single LED Light Pods XIL-OP110CKIT 10 Narrow Beam Pattern in 1 store with lowest price $299.00 in AutoAnything. For detailed price comparison of Vision X Optimus Square Single LED Light Pods XIL-OP110CKIT 10 Narrow Beam Pattern check table below.
Merchant | Price | - |
AutoAnything | [show price] |
Vision X Optimus Square Single LED Light Pods XIL-OP110CKIT 10 Narrow Beam Pattern description from AutoAnything
LED Lights by Vision X. Vision X Optimus Square Single LED Light Pods Features - For a big lighting upgrade in a small package, deck out your ride with the Vision X Optimus LED Single Pod. Pumps out up to 693' of usable light for unbeatable long-range illumination. Uses a single 10-watt LED bulb that draws minimal amps yet cranks out 860 raw lumens. The smart IRIS reflector shapes the light into a tightly focused blast. Available in multiple beam patterns for wider coverage or epic distance. Vision X Optimus Square Single LED Light Pods - Best Price on VisionX Square Optimus Single LED Pods. For the top selection of Vision X Lights shop online today. The Vision X Optimus Square Single LED Light Pods - Best Price on VisionX Square Optimus Single LED Pods will improve and personalize your vehicle. LED Lights by Vision X - selected by many auto enthusiasts in the top automotive discussion forums. Vision X Optimus Square Single LED Light Pods for your vehicle will deliver the results you are looking for! Vision X Optimus Square Single LED Light Pods - Lights - LED Lights.
Customer review
The led bulbs exceeded my expectations of high quality and style Vision X led bulbs.
